I was doing a batch conversion of some MPEG2 files I received recently. Converting them to DV for compatibility with other DV files I will be editing them with. I decided to turn them into DV, thinking that they would retain all the quality they currently have, due to the fact that I was making the files bigger and less compressed but when I look at the DV-Type2 (AVI) file I created, I am getting VERTICAL blocks on the finer details! What the hell is going on? It's not a field type issue because this is actual artifacting that I am seeing on the monitor. It only looks slightly better on the TV, due to the aperture grill.
Your miserable life is not worth the reversal of a Custer decision.
Post a screenshot here. You can make video screenshots with media player classic, File->Save Image.
I'm at work, right now. But it's definitely a distortion caused by reinterpreting the data. I was expecting the conversion to a larger file would retain the original quality. I did interleave audio but audio is interleaved with video when you capture a DV clip anyway. Perhaps I should try the audio seperately and see what happens?Originally Posted by BaldrickYour miserable life is not worth the reversal of a Custer decision.
What ersolution and bitrate are the original mpegs? (I suggest you use bitrate viewer if you don't have this info)
I'll check it out tonight. They seem to be pretty large but then again they have very little motion involved in each clip.Originally Posted by bugsterYour miserable life is not worth the reversal of a Custer decision.
Is there a way to batch normalize audio of MPG2
By mehnihma in forum AudioReplies: 3Last Post: 6th Mar 2010, 00:15 -
video conversion to mpg2/vob/h264..
By krohm in forum Video ConversionReplies: 14Last Post: 10th Jun 2009, 14:32 -
Batch conversion
By karlitus in forum ffmpegX general discussionReplies: 2Last Post: 23rd Nov 2007, 11:33 -
Converting MPG to AVI type2 (batch)
By statman24 in forum Video ConversionReplies: 8Last Post: 19th Jul 2007, 04:30 -
batch rm conversion
By kcchesnut in forum Video ConversionReplies: 1Last Post: 1st Jul 2007, 20:01
