I am thinking of buying a dual layer dvd burner. However, the store does not sell the disks-DVD R9. Maybe I am misunderstanding something(or maybe I am just dumb as a rock).
Can you fit 9.4 GB on regular blank 4.7GB disk with a dual layer burner? Or, do I have to buy the DVD R9 disks? Not many places sell the DVD 9 disks. I guess that is why I am confused.
probably a dumb question...
No, you can't fit 9.4GB or it is actually 8.5GB on a 4.7GB (or in the computer world it is 7.95GB and 4.37GB...). You must buy dvd+r dl/d9 disks, they are still pretty expensive.
The best place to buy is a store in an area where there is heavy competition. That way, when prices come down, they come down faster. Anyway, it doesn't matter where you get the disc from in the case of DL, they are that expensive that you might as well buy another copy of the legit version in a lot of cases.
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
Probably a dumb burning question
By neroguy in forum Newbie / General discussionsReplies: 14Last Post: 7th May 2011, 04:34 -
Dumb PS3 Question
By wulf109 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Feb 2009, 07:56 -
Dumb PS3 Question
By wulf109 in forum Off topicReplies: 2Last Post: 3rd Feb 2009, 22:36 -
Really dumb USB 1.1 Question
By ahhaa in forum ComputerReplies: 4Last Post: 1st Jan 2009, 15:50 -
Dumb question about 768p
By winterwolfes in forum DVB / IPTVReplies: 28Last Post: 2nd Jan 2008, 16:50
