I am using easy cd creator 5 vcd maker and it makes the vcd fine and it plays on my dvd player but towards the end, the vcd stops on the same frame every time. is there anything i can do? ive already tried to burn it a bunch of times
- Check if it freezes on your computer too.
- Check that your mpeg file doesn't freeze too.
- Try using Nero instead of Easy CD Creator.
- Try a different brand of CD-R
I only dream in black & white...
MSN: paschendale@gmail.com
Why wont subtitles work?
By .deathnet in forum SubtitleReplies: 2Last Post: 3rd Mar 2009, 12:01 -
laptop vga port wont work on my moniter
By kingnat2 in forum ComputerReplies: 2Last Post: 12th Jul 2008, 17:47 -
Disc will/wont work between different DVD players.
By Scroogle in forum DVD & Blu-ray PlayersReplies: 3Last Post: 17th Jan 2008, 14:41 -
DVD Decrypter wont work with my external drives?
By dazza555 in forum DVD RippingReplies: 4Last Post: 23rd Jun 2007, 19:04
