Hi
I have just read one of the posts in this forum, about how to get 4 episodes of a tv series onto a dvd and some people suggested that the way to do this is to lower the bitrate. So my question is how is it possible that when you buy a tv series on dvd that they manage to fit 4 episodes onto the one dvd without a loss of quality?. Is it because the production companies have expensive software or something?
Thanks in Advance
nah, it's cause it's a dual layer dvd and your puting it on a single layer dvd...basically you have half the space to work with. somethin like that i would use dvdrebuilder
Yes, and most of all, they have better source material. However, depending on episode length, (I suspect 1/2 hr each?) given good source material, it will also come out with high quality when encoded/authored as DVD even when produced with the "pro-sumer" tools avalable to us mortals.
/Mats
Problem with burning DVDs...wont fit but should
By JediMindTrick in forum Newbie / General discussionsReplies: 7Last Post: 16th Apr 2010, 09:37 -
n00b wont fit? WMPfile?
By karrbass4life in forum Newbie / General discussionsReplies: 3Last Post: 16th Jan 2008, 00:09 -
How many can I fit on a DVD?
By love2learn in forum Newbie / General discussionsReplies: 1Last Post: 17th Nov 2007, 12:46 -
Mpeg files wont fit onto one DVD
By jayman34 in forum Newbie / General discussionsReplies: 5Last Post: 13th Jul 2007, 03:43 -
Help to fit two DVDs into 1
By heretic1 in forum Authoring (DVD)Replies: 1Last Post: 12th Jun 2007, 23:57
