I'm trying to get a VCD of "Enterprise" to play on my laptop computer DVD player, but I'm not having any luck.
My friend used Nero to make the VCD, but PowerDVD and WMP won't recognize it. However if I put in a VCD made with Easy CD Creator's VCD program, it works fine.
I think the problem has to do with the fact that Nero is converting the files to .DAT files, which PowerDVD and WMP won't play. If I click on the DAT file itself and run it, it'll play, but only in mono sound...no stereo.
Anyone have any ideas as to what the problem is or how to fix it? I'm using Windows XP Pro running WMP 8.0 and PowerDVD XP 4.0 on a Dell Inspiron 8000 with LG DVD drive, model number DRN8080B.
- Jason
Results 1 to 1 of 1
trouble playing dvd
By speedoman955 in forum Newbie / General discussionsReplies: 7Last Post: 2nd Dec 2009, 08:08 -
Having trouble playing 1080p
By godvsnietzsche in forum Software PlayingReplies: 8Last Post: 24th Nov 2008, 19:09 -
trouble playing .avi files
By starkythesparky in forum Software PlayingReplies: 5Last Post: 12th Jun 2008, 23:54 -
Having trouble playing old vhs-c tapes
By Columbusbill in forum Newbie / General discussionsReplies: 5Last Post: 31st Dec 2007, 22:49 -
Trouble playing burned DVDs on my stand alone
By collin_stevens in forum MacReplies: 2Last Post: 12th Oct 2007, 17:51
