I am having trouble with DVD Lab Pro and the concept of using
4x3 and 16x9 movies together on one DVD-R. I have read some
help files on the DVD Lab forums, but it is just not happening for me.
Could some kind soul do a screen capture of both the DVD Lab
Project Window and the Connections Window of a project where
they have implemented 4x3 and 16x9 movies, and upload the jpeg
here on forum, as that would be a great help.
After all, a picture is worth a thousand words
I would be even more grateful if someone could PM me and organise
to email me a simple 4x3 and 16x9 Project Template. Of course the
template would tell me that it cannot find the movies, but at least
I would have the basics.
Thanks in Advance...
Have you created separate VTS for the 4:3 and 16:9?
Yes I have.
What I cannot grasp is the menu concept. I have two movies, one is 16x9 the other 4x3. I just want one menu, displaying the two movie titles, and these would link to the appropiate movie.
That is why a Connections diagram (jpeg) would make all the difference. I could actually see what is happening, and what links with what. -
zenzen1,
Place the menu in VMG space (domain), create two buttons, and link to each movie. One menu that can call either VTS movie.
Set the return link of each movie back to the VMG menu.
It's that simple.
Just remember to set the appropriate audio stream in VTS space (or learn to program VM commands - not necessary though) if you have multiple audio ES' (elementary streams).
Brian-----------------------------------------------------
There is a reason why God gave us one mouth and two ears!!! -
Zenzen1,
Take a step back and learn about DVD structure and domains (space).
Here is an excellent starting point that walks you through both topics. You will learn alot without realizing it.
Armed with this knowledge, you can go back to DVD Lab Pro (DLP) and understand why some linking works and some doesn't!
http://www.dvd-replica.com/DVD/index.php
Are you are only wanting a play button for each video? If you don't need scene selection menus you only need the VMG menu. Delete the default VTS menus that are not used or the compiler will complain.
The VMG menu will be your main menu. Add links that point to the start of your movies. Be sure to set the aspect ratio for each movie VTS. Note however that some kinds of links cannot be made into a VTS from the VMG. But just PLAY buttons will work fine. From the connections window just link the movies back to the VMG and you'll be all set.
Shrink (Reversed Stretch) 16x9 to 4x3 without black borders
By Paker in forum Video ConversionReplies: 4Last Post: 14th Sep 2010, 11:09 -
Converting 16x9 video to 4x3 letterboxed in Sorenson Squeeze
By pjbarbour in forum Video ConversionReplies: 0Last Post: 10th Mar 2010, 09:49 -
Stretch 4x3 menu to 16x9
By kpic in forum Authoring (DVD)Replies: 10Last Post: 31st Jan 2010, 12:45 -
4X3 capture to 16X9 export? (minidv)
By bufalo in forum Authoring (DVD)Replies: 12Last Post: 13th Jun 2008, 01:07 -
DVD converting 16X9 to 4X3 letterbox
By DVDBear in forum Newbie / General discussionsReplies: 3Last Post: 26th Jun 2007, 04:10
