Does anybody have any information on if DOUBLE-SIDED dual-layer discs will ever be released? Until that time I see no reason to buy a DL drive, because I can get 9.4 gigs on a double-sided single-layer disc as it is, why would I spend all that cash just to fit the same amount of data on a disc?
Also, does anyone know when DL media will start becoming more available? As of right now you can find it maybe in 2 online vendors if you're lucky, for around $8 a disc. I remember when DVD-R's, and even CD-R's were at this point, but it seems DL price drops and media availability is progressing even slower.
On the first point you make. You wont have to get up to change the disk over.... Some people are lazy like that...On any 2 sided d/l who knows...
2nd point seem to remember seeing something about manufactures having a too higher failure rate in production of d/l disk. If they cant make them in high enough numbers the price wont fall...Not bothered by small problems...
Spend a night alone with a mosquito -
There are some dvd that are huge in, and any compression done to fit on a 4.7gb single-layer size will weaken the quality, especially those tv-series dvd.
why would you care about the availability of the DL disc, when you're not going to buy a DL drive and rather have a 9.4gb disc for more the data storage.
New to double sided dvd's - Burning Hi Quality Media Files
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2012, 21:50 -
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 17:13 -
Double-Sided, Dual-Layer DVD media?
By dgpretzel in forum MediaReplies: 22Last Post: 15th Apr 2008, 16:03 -
Dual-Layer Double-Sided DVD's turnover?
By Deisel Weisel in forum DVD & Blu-ray RecordersReplies: 6Last Post: 22nd Nov 2007, 22:23 -
How do I convert double sided dvd to dual layer dvd?
By acid_burn in forum DVD RippingReplies: 2Last Post: 22nd May 2007, 05:04
