  1. Hi there!
    Say I have a clip, but I want it to play backward, I mean really create a new clip with the order of the frames inversed. Is there a program that enables me to do that? I hope you understand what I mean...
    Thank you!
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    You can do it pretty quickly and easily with AVISynth. Instructions here. Then open this avisynth file in TMPGEnc or Virtualdub and encode to either MPEG or AVI.
    If in doubt, Google it.
  3. hey thanks! I'll check it out!
