  1. I'm green on bitsetting. Is it just for RW to Rom, or is it also for -R/+R to Rom for maximum compatability?
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    bitsetting is only for DVD+R and it depends on what dvd burner you have. not all dvd burners enable bitsetting.
  3. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    Just to add a clarification +R means +RW also.
  4. So in what circumstance does bitsetting become desireable?
  5. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    My 3rd dvd player is an Apex 600AD canadian model. It has no probems with DVD+R and DVD-R and I've never tested DVD-RW but it refuses to recognize DVD+RW unless I change the disc bit id to DVD-Rom. So it can make a difference for some players. If your player plays DVD+R and +RW right out of the box like my other players do, then you would not have much need for this feature.
  6. Will old players (5 years old etc.) that do not play -R/+R be able to play these disks if the bitset is changed to ROM?
  7. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    I would think you would have to try it on the dvd player to find out if no one has listed it in the dvd player section.
    I have one made in 2001 & it won't play any format other that a store bought dvd-rom, it will not play dvd+r, dvd-r, or dvd+r changed to dvd-rom. but i found one in the dvd player section that a friend has that will not play dvd+r or dvd-r but in there someone listed that theirs played one set to dvd-rom so i burned some booked at rom and am gonna test them on her player.
