Is there an equation, or anyway to tell, what my average bit rate can be in compressor for X length video when the audio I use is .ac3?
When you add your own templates, it gives you an estimate of how many minutes will fit onto a DVD, but that estimate is using .aiff for the audio file.
Any idea?
Also does .ac3 audio work with all dvd players/sound systems?
Give Mr. Bitbudget a try
http://www.planfilmberlin.com/mrbb/mrbitbudget0.5bX.sit
.ac3 is universally supported on DVD players which also convert the sound to standard analog stereo through the line output or RF cable. -
The equation is rather simple. If you're using single-layered DVD-R media, then you have 4,700,000,000 bytes to fill = 4,589,843 kbytes = 4482 MB = 4.37 GB. If you use 192kbit/sec AC3 (common bitrate for stereo audio), if X (length of film) = 2hrs = 7200 seconds * 192 kbit/sec = 1,382,400 kbits. or 172,800 kbytes = 168.75 MB, leaving 4313.25 MB for video (assuming you have a single audio track. If the video is 7200 seconds, that means you have to have the bitrate below 0.599 MB/sec, or 4.79 Mbit/sec (4313.25 MB / 7200 seconds * 8 bits/byte). You might want to leave a little bit of extra space for the DVD menu and such, so if you want to make it 100 MB smaller (should be enough space for a decent motion menu), 4213.25 MB / 7200 seconds * 8 bits/byte = 4.68 Mbit/sec. Compressor's VBR (Variable Bit Rate) encoder isn't exactly accurate (and depends on how much complexity and motion is in the video you're using), so it may take a bit of trial and error before you find a setting that gives you the exact size you want.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
BitrateCalc appeared on versiontracker a couple of days after this thread started. It seems we don't all have to be math majors.
Or have completed grade six math.Originally Posted by willrobIf it isn't broken, take it apart and find out why.
blog: deadsierra -
Thanks for the Bitrate Calculator, it works great!
Man, I'm gald I didn't have your sixth grade teacher!
It's not the math that I have a problem with, it is remembering all the bits bytes and whatnots.
What is the best compressor to use???
By BobAchgill in forum EditingReplies: 7Last Post: 13th Sep 2011, 06:55 -
Compressor gives me .h264, but....
By whoisquilty in forum MacReplies: 4Last Post: 10th Jan 2011, 11:38 -
HDV7 compressor is ..... ?
By ermetekos in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 3rd Nov 2009, 14:00 -
Compressor Needed
By mytabbycat in forum MacReplies: 4Last Post: 3rd Nov 2007, 05:54 -
Why is compressor lying to me??
By whiff79 in forum MacReplies: 2Last Post: 4th Jun 2007, 14:38
