when you back-up a dvd to dvdr and the dvd has easter eggs..will the easter eggs be copied unto the dvdr? and will you be able to access it...thanks
if you do a "full" backup, yes
If you're doing a full-disc BU, then yes. If segments, or menu entries are removed, then it depends on what is removed.
Remember, "Easter Eggs" are just creative or hidden buttons and segments.
HTH
