I have a concert on DVD and I want to copy the PCM audio track to a CD, can it be done?
Posted this in the wrong forum by mistake.
Copyright issues notwithstanding, yes, this can be done. You would need to downsample the PCM audio from 48khz to 44.1khz.wav (using Soundforge, Wavelab, Audition or CoolEdit, for example)
This should then be playable on a CD player.
Arky ;o) -
Use DVDDecrypter->IFO mode->Stream Processing->demux.Make sure to select no file splitting in Settings.
Then use the programs listed above or CDWave to split and convert.
No sound from a PCM audio stream using DVDFab DVD to AVI file.
By loninappleton in forum AudioReplies: 8Last Post: 5th Dec 2011, 05:27 -
Authoring DVD with four subtitle tracks and PCM audio?
By bizzybody in forum Authoring (DVD)Replies: 7Last Post: 28th Feb 2010, 23:17 -
Audio options in DVD player, RAW or PCM?
By dzsoul in forum DVD & Blu-ray PlayersReplies: 0Last Post: 31st Dec 2009, 06:00 -
Problem with PCM Audio track when Burning DVD
By darnhs in forum DVD RippingReplies: 7Last Post: 11th Aug 2008, 22:07 -
audio PCM to MP2 while retaining DVD menus
By navels in forum Video ConversionReplies: 2Last Post: 20th May 2007, 16:51
