Results 1 to 30 of 31
  1. I'm not trying to advertise, as most of you could probably do the same thing I can do, I just want feedback on my site. Any suggestions on how to make it better, etc.
    Thanks for the help.
    http://www.valuedmemories.com
  2. Suggestion 1:
    adam@valuedmemories.com sounds nicer than athole
    Suggestion 2:
    Add a testimonials page, people like those
    Suggestion 3:
    The contrast on the navigation buttons could use some work. Black on Dark Purple is tough to see.
  3. Get rid of the comic (kiddy) font, as you are a professional. When I see comic (kiddy) font, I think a kid did it and not a professional
    Put in a table buffer so the text doesn't hit the right side.
    Make sure all your fonts are the same, same size (unless denoting something special), same color.
    Format it more like a peice of paper, rather than the size of the windows once you get past 640
    Originally Posted by jagabo
  4. Yeah, I guess athole is too close to ahole, so it would be smart to just use Adam.
    I will have to work on a testimonial page, thanks.
    And I want to get rid of that whole nasty frame some time. I made that with Microsoft Front Page along time ago, and I think it is hideous. I am still trying to find a design I like though.
    Any particular font you would reccomend over comic? One that isn't ugly, that every body has?
    Thanks!
  5. Guest
    Guest
    I agree. Reminds me of 1996. You are presenting a technical service, so use something more streamlined. I think the content and structure are good, just needs a makeover. I'll see what I cant dig up.
  6. Guest
    Guest
    try this site
    http://www.1001freefonts.com/fonts/afonts.htm
    I like
    accidental president
    avdenture subtitle
    anabolic sheroid
    aqua duct
    arbor crest
    atarian system
    automation
    These are just a few from the "a" section. These would be good in your title and nav button gifs. You should use a standard windows font for the text body. Id work on the color scheme as well.
  7. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    (This is strictly for your benefit, I'm not just cutting you down)
    Overall the page is overly simple and not professional. The colors and fonts are childish. The graphics, such as the DVD image in the top left, look like clip art and cheap.
    You need to have a "look" with your website. You need to have a stylish logo that you can adapt to various items and even include on your products possibly.
    #1 thing you should do is a complete rewrite of the website from the ground up. For the HTML here are some key points:
    -NO FRAMES!!!!
    -Use CSS!!
    -Make original art for the site
    -Make an overall theme and look for your site
    -Use AT MOST 2 fonts for the entire website
    Hope this helps ya'. Let us know if you need any more help.
  8. I agree with tgpo, start from scratch
    Begin with a piece of paper and draw out the site.
    Fonts are up to you, and there are a million of ton of them to choose from. Comic is the last one you want. Personally, I only use arial, times roman in clear text, but in images I've used many others.
    I also agree, use CSSs, it's much easier to mantain the fonts and colors
    I think the biggest thing is to start from scratch and have a basic plan/idea/design. Then follow it thru for the whole site.
    If you find a page you like, just go up to "file" then "save as". Then edit that page until you like it
  9. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    yeah it looks a little basic...needs some life... if you have the time i would maybe put in some time with flash
  10. Guest
    Guest
    I agree about flash. Most browsers come with the plugin. You can have much more detailed sites that dont take forever to downlod.
  11. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    NO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !
  12. Guest
    Guest
    Dont knock it till you try it. Your font,color,layout choices remain intact.
  13. Yes, I Know Roundabout's Avatar
    Jul 2003
    ...in and around the lake
    I would Google some other websites that do the same thing like this one to get an idea of a better layout. You could even copy the basic design idea and change it the way you want it.
    Ethernet (n): something used to catch the etherbunny
  14. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    YES!!!!!!!!!!!!!!!!!!!!!!
    :P
  15. Any good guides around on CSS?
    Any inexpensive programs for the Mac reccomended for coding it (CSS or HTML)? I do much better with something visual...not just BBedit.
  16. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    BBEdit is the best you can find. Begin with Photoshop and code with BBEdit. Ditch the visual programs and learn to code. It'll help you in the long run.
    http://www.w3.org/Style/CSS/
  17. Video Restorer lordsmurf's Avatar
    Drop the spinmeister intro. People see right through BS. Your tape will never turn to pure fuzz.
    Most shelf life is more like 50 years, but even then, all theory.
  18. Member Conquest10's Avatar
    Chicago, IL
    Haven't done any web stuff on OSX but I recommend simple text. Its easy and free.
    No flash. No Comic Sans font (ask a typography guy what he thinks of it).
    His name was MackemX
  19. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    I can't find that program.
    Isn't that the OS 9 text program?
  20. Member Conquest10's Avatar
    Chicago, IL
    Yeah, I used to use it on OS9. What's the equiv on OSX?
  21. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Textedit
  22. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Originally Posted by Dr.Gee
    try this site
    I like
    avdenture subtitle
    anabolic sheroid
    aqua duct
    arbor crest
    atarian system
    automation
    That's no good unless the font is installed on the users computer otherwise they'll see the default browser font.
    As suggested use CSS to format your page... No flash, too many reasons to state.... Learn how to use a image editor. Look for the anti-aliasing option for objects, it's your friend. Also make sure all your images are the smallest file size possible. Any image you intend to use on more than one page should be in the same folder on your server.
    Important: Use Keywords in the title and have a different title for each page.
  23. Simply avoid making your site too flashy - there's nothing worse than a page that takes 20 minutes or more to load
    Especially the first page - that's the ultimate nightmare for first time vistors to the site
    Also keep in mind that many people still use dial-ups - and it's far more important to focus on your services/site content than how fancy the site looks.
    You can go for a cool or professional look but keep it as basic and simple as possible.
    Here's another CSS Tutorial and Sample -
    http://www.w3schools.com/css/css_intro.asp
    http://www.w3schools.com/css/demo_default.htm
    http://www.w3schools.com/css/css_colors.asp
  24. Guest
    Guest
    try this site
    I like
    avdenture subtitle
    anabolic sheroid
    aqua duct
    arbor crest
    atarian system
    automation
    Read my post..I suggested using those fonts when making title and button gifs not for body text.
  25. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    alright, I have to get this crew's critique on mine as well...
    Housepig dot com v1.0.
    fire away.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  26. Originally Posted by housepig
    fire away.
    I thought I'd never see colors worse than the original vcd colors
    But I have now
  27. Member Conquest10's Avatar
    Chicago, IL
    fire away.
    Its pretty good just being one page. Do you really need frames? CSS can be used to format the page. Colors could be better.
  28. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    Conquest -
    I went with the frame because, as more content is added, it's going to be a menu bar. I'm going to check out the CSS links earlier in the thread, if I can do it with CSS, I'll probably switch over - I'm just not familiar with it.
    nobody likes my colors? should I change them to yellow text on a white background, with a lot of <blink> tags?
    - housepig
    Housepig Records
    out now:
  29. Member Heywould3's Avatar
    Apr 2002
    always on the move
    Adam,
    before your topic gets totally hijacked il ltry to bring it back.. hahah.. i think they are all correct.. it looks like it was done by a young kid that doesnt have lots of experence.. in order for me to want to try someone for tech services. i would want to see a nice page.. feedback is a nice touch.. but before you get into that.. i would just redo the page from the beginning.. the idea of saving a page from someone else and changing it to be "yours" is a great idea.. a huge time saver and it will look nice.. BUT if you take tha method.. make sure you go in a manually do one yourself so you can maintain it and know how its done.. . no frames.. NO flash .. and no sliiy clip art and kiddy font.. stick with arial times. roman etc.
    oh yues contrast is a big point.. dont use strange combo colors.. like green/yellow red/blue. orange/black red/black.. purple/and anything.. off colors will be to strange.. try looking through the themes for word or FP and get and idea of what color combos to use.. it has to be easy on the eye.. not flashy
    my $0.02
  30. Video Restorer lordsmurf's Avatar
    fire away.
    Orange burns my eyes. The other colors are fine.
