Dear friends,
do you know with we can copy a dvd with the audio at / with a higher audio level?
Thankfuly,
J.J.![]()
Closed Thread
Not without a lot of work. Assuming an AC-3 5.1 audio track, you will have to demux the audio back to 6 mono wav files, increase the audio volume in each, reencode back to AC-3 5.1, then remux it back into the dvd structure. I'm not sure if this can be done while keeping menus intact. It is a lot of effort for something that can be fixed by turning up the volume on your kit.
Do not cross-post:
https://www.videohelp.com/forum/viewtopic.php?p=1108316&highlight=#1108316
Adjust audio level
By drgt in forum Newbie / General discussionsReplies: 7Last Post: 11th Aug 2011, 13:03 -
Ripbot Audio Level
By wulf109 in forum Blu-ray RippingReplies: 0Last Post: 20th Nov 2010, 13:03 -
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 07:57 -
Video Audio Volume level
By Directlinq in forum Video ConversionReplies: 2Last Post: 16th Nov 2009, 12:43 -
Setting songs to same audio level
By andre477 in forum ComputerReplies: 8Last Post: 16th Jun 2007, 08:57
