Results 1 to 9 of 9
run em all through tmpgenc again and then tmpgenc dvdauthor as separate tracks
If you want to join them, make them all ONE track in DVD Author. Adding them as seperate tracks will cause the DVD to return to the menu between segments.
"Rarely is the question asked: Is our children learning?"
George W Bush - Moron -
Here is 1 solution...i use Nerovision Express 3 to combine as many mpegs or avi's OR VOBS. into 1 track and with menus and chapters...AUDIO CAN BE LPCM OR AC3-2.0.....it will automatically reduce the BITRATE to make everything fit on 1 dvd....BE WARNED..A LOW BITRATE MEANS REALLY GRAINY VIDEO!!GOOD LUCK
Originally Posted by mitshubishi
Use a real encoder like CCE, TMPGEnc, MainConcept - not Nero or other half baked "doitallforyouwithjustoneclick" kind of app.
/Mats -
Each to his own.
/Mats -
TRU BUT TO HEAR PEOPLE PEOPLE PUT DOWN A PRODUCT THAT WORKS SO WELL AND IS EASY TO USE..baffles me
Could it be that for every thing that Nero (claims) to do, there are at least one (often many) other tool, mostly free, that does it better? If a process using 4 apps and 10 clicks gets me a better end product than a process of one app/one click, I'm for the former. But again, each to his/her own!
/Mats
joining edited clips
By gargoyle62 in forum EditingReplies: 1Last Post: 22nd Nov 2011, 21:10 -
Help for adding Fade In/Out and Joining many clips together
By joberrick in forum EditingReplies: 1Last Post: 11th Jul 2011, 20:44 -
Joining several .MOV clips
By natty in forum EditingReplies: 18Last Post: 28th May 2009, 11:27 -
Joining 2 different video clips without re-encoding one of them?
By Og in forum EditingReplies: 2Last Post: 7th Jan 2009, 01:54 -
joining avi clips
By natty in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 12:32
