  1. Member ntscuser's Avatar
    Mar 2003
    Sorry if this has been asked before but is there any way of adding fonts to DVD Author for use when creating menus? For example, I have fonts installed in windows for use with Star Trek and Star Wars related clips which I can use with various design programmes but when I open the fonts menu in DVD Author none of these is listed. I've looked in the Pegasys programme directory to see if it has a separate folder for fonts but was unable to find one there.
  2. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Not sure but that might be an issue with the font itself. Go to control panel>fonts compare the ones that aren't listed with the ones that are and see if they are the same type (i.e. True Type).
  3. Member ntscuser's Avatar
    Mar 2003
    That would appear to be the problem. Particular font was 'blocked' as it originated on another computer. Have now 'unblocked' it. Thanks for the help.
