Good morning friends,
I have handled several video (AVI) files already with VirtualDub v1.5
usualy extracting the audio to .WAV file and later encoding it to
SVCD / DVD movie.
in all cases there was either no skew or very small skew between video
and audio tracks, so it made no difference for the later encoded movie.
This movie is exceptional since there is a very large skew which is noticeable while playing the movie ( the skew grows bigger along with the movie).
I searched this forum for relative information, with no success.
I attached a picture of two screen captures.
Thanks in advace for any help.
Gradual drift is mostly due to:
A) Bad/undecodable frames in the video scattered thru the movie
B) Not going thru all hoops and loops ncessary for a succesful frame rate conversion (your source AVI and dest SVCD/DVD have different frame rates).
/Mats -
There are guides for both situations to be found left.
If you're converting frame rate, I suggest you don't - It's much easier to stick to the source framerate thru the whole process. At least if you're in PAL region, you'll probably be able to play NTSC material as well as PAL - things are a little different if your native TV system is NTSC...
In these matters, it helps if you fill in your profile!
/Mats
Big audio problem
By gynno in forum AudioReplies: 6Last Post: 18th Feb 2012, 22:39 -
Is there a way to see how big the audio part is in a mkv?
By AndyD in forum Blu-ray RippingReplies: 17Last Post: 22nd Nov 2010, 03:33 -
Audio skew correction causing static in begining of audio.
By NextJinGamer in forum AudioReplies: 1Last Post: 3rd Sep 2008, 15:33 -
How to add/fix audio skew in VirtualdubMod?
By neomaine in forum Video ConversionReplies: 2Last Post: 4th Jan 2008, 14:27 -
Problem with SKEW audio
By themaster1 in forum EditingReplies: 0Last Post: 22nd Jun 2007, 22:35
