when you have a source file in 23.97 f/s, how do you change it to 29.97 so that it will play properly in a DVD player as a vcd? also how do you make sure the audio stays in sync when you convert it?
Most DVD players will play a 23.976 fps VCD - that's how I always make FILM VCDs. Give it a shot and see if it works for you.
Also you should get better quality at a given bitrate by leaving at 23.976 instead of converting to 29.97. Since you have fewer frames, more bits can be allocated to each frame. The DVD player does the 3:2 telecine process on the fly when you play the VCD.
Both 23.976 and 29.97 are part of the VCD standard. JHebert is right, the less converting you do the less quality loss.
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 18th Sep 2011, 00:06 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 06:44 -
To convert or not to convert a pal dvd
By nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 02:35
