which version of it could copy the dvd onto the hard drive? the one I found only has settings to copy from the dvd to a blank dvd.
all versions copy the dvd to the hard drive. before burning to dvdr, dvdxcopy has to copy the contents to the hard disk first. just locate this folder on your hard drive and copy the contents to another location on your hard drive when dvdxcopy prompts for a blank dvd, but do not close dvdxcopy at the time of doing it. i cant remember where cos its been ages since i used dvdxcopy and NEVER will do again.
why would you want to use dvdxcopy? dvdxcopy is crap, it adds its own annoying warning screen.
try using some better freewares such as dvd decrypter and dvd shrink. -
Originally Posted by grandizer74
DVDXCopy is crapware IMO
BTW, what do you mean by "found" ? In the trash ? On the street ?If in doubt, Google it. -
DVDXCopy takes freeware applications and adds a drm delphi frontend that calls home.
321Studios had a lousy business reputation. It is wrong to sale freeware applications.
Oh yeah, DVDXCopy sux. -
Besides, 321 Studios has gone out of business after being sued by major companies (do a google search for more information) so dvdxcopy no longer receives any support or updates.
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
