I am trying to choose between a Panasonic DMR85 and a LG4820. Both have an 80gb HDD and similar features though the LG has a DV input and uses DVD-RW both which I prefer. Both units are very similarly priced in Brisbane, Australia. Any comments from users of either would be greatly appreciated. As I have a lot of DVD movies ex DVD Shrink the ability to play these would be essential. My current LG player often freezes but a cheap player seems to manage OK
I'm looking at the Toshiba with 80gig hard drive, have you checked it out? It sells for $1249 at "HARDLY NORMAL" in Melbourne, and it does + - RAM.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
Thank you for that. I will look that one up. I would probably also like a JVC but that seems a bit dicey. The Panasonic is just under 1200 and the LG is 1200 so they're pretty identical. I haven't looked at H/N. They're usually a bit dearer than others
Believe me that H/N staff will ALWAYS drop their prices. This is what I do. I get my best price from other stores and then ask H/N "can you beat this?" and they will.
BTW The Toshiba has a front DV slot."Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
Looking for sound card recorder (not Total Recorder)
By jimdagys in forum AudioReplies: 1Last Post: 7th Jan 2011, 19:23 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 02:05 -
Will a DVD-Recorder to DVD-Recorder copy lose quality?
By blackmetal in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2008, 04:54 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 17:59 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 21:19
