Hello,
I'm trying to fit quite a few mpeg-2 encoded music videos on a DVD. I can only fit 7 or 8. Is there any way to have a ".vob" like compression.
I know of commercial DVDs that fit 30-40 music videos on one DVD.
How can I do that ??
Your suggestions are very appreciated.
Thanks,
Kay
Results 1 to 16 of 16
oooh ... pick me .. pick me - a trick question.
lower the bitrate -
Oh.. most certainly playable in a DVD player.
And why is it a trick question ?? !
Thanks ! -
Originally Posted by Garf4u2
The first rule of video is that size = bitrate * time, so to lower the size (and therefore allow for more time to fit), lower the bitrate when encoding to MPEG-2 files.If in doubt, Google it. -
i have a good solution for you.
Use a bitrate of around 6000kbps/7000kbps for the vid, and when making the DVD, tell the program your DVD is a large one, 8.5GB should usually do it (dual layer). Let is set up, prepare and make the .iso file or .vob files for the DVD. but DON'T BURN IT YET! open up DVDShrink, and use that to compress the 8.5GB DVD down to a single layer disk. Quality is very good, and can fit alot more onto it.
Spook2yk/Dan -
I will certainly try your suggestions.
However, I already have some videos encoded with a higher bit rate. I don't have the source files anymore. Only the mpgs. How can convert it to lower bit rate ? TmpgEnc doesn't accept the file.
2) I'm using NeroVision to author this DVD. It doesn't allow me to change it to higher capacity DVD (8.5GB as suggested). What do you suggest ?
I really would love to have a solution to this. I like to have my own collection of music videos !
Thanks,
Kay -
Easier is to open the mpeg 2 file in Dvd2avi, save a project file, then open this (.d2v IIRC) in TmpGenc and encode that - video only. dvd2avi will de-mux the audio when you save the project, so just use that as-is in your authoring program along side the newly encoded mpeg from tmpgenc. -
I'm usign LPCM. I can change it to AC3 if TmpgEnc or other encoder accepts the file. How can I can re-encode my mpeg-2 videos (without source file) to lower resolution and AC3 audio ?
I don't have the source files though. (.vobs) etc. None of the video encoder accepts the mpeg file. Don't I need to re-encode video also ? Not just audio using BeSweet, right?
spooky2k was on the right track. Just author the DVD with the mpgs you have and don't worry about being oversized, then use DVD shrink to make it fit a standard DVD.
I have a 4hr mpeg 2 video and i need to fit it into a 4gb dvd-r
By missyfy in forum Authoring (DVD)Replies: 4Last Post: 3rd Feb 2011, 04:12 -
Got two .avi files and need to pare them doen to fit on one dvd, help!
By BroCraig in forum ffmpegX general discussionReplies: 8Last Post: 25th Aug 2009, 12:35 -
Need to compress 5 VOB files to fit in one 4.7GB DVD...
By pmolson in forum Video ConversionReplies: 12Last Post: 20th Oct 2008, 17:52 -
Mpeg files wont fit onto one DVD
By jayman34 in forum Newbie / General discussionsReplies: 5Last Post: 13th Jul 2007, 02:43 -
How to burn DVD files that don't fit on DVD?
By aqualung2003 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2007, 00:43
