I'm totally lost on this and have exhausted days trying to fix it. Here's my problem. I cut videos from different sources (Some i capture, some i download, some friends capture) I capture mine with virtualdub, and use tmpgenc to encode it as mpeg2. I take all of these clips and edit them and add effects in Vegas Video. I then render it as an uncompressed avi because i dont like vegas video's mpeg2 encoder. I then take this avi and render it with tmpenc or recently i've been using cce with a 5 pass vbr. If i play this finalized mpg on my computer or on my tv through my comptuer quality is amazing, crystal clear. The problem is when i put it on a dvd the clips that i capture and my friend capture are fine, the clips though that i get from different sources are jumpy and i can see the interleaving lines. The entire 1 minute clip would be jumpy and jittery, when the clip changes to another video (one that i capture) it goes back to playing back fine. I am a somewhat of a noob so the only thing i could come up with was maybe the field order was different in my vidoes and the other videos. I was thinking if i render the avi as progressive instead of interleaved would that get rid of the interlace lines. i dont know that probably makes no sense what so ever. Any help would be appreciated. Thanks!
Originally Posted by johnnysc
It sounds like you are capturing interlaced footage, but some you are capturing bottom field first, and some top field first. When you pull it all together, some are getting reversed. On the PC everything looks OK because your s/w DVD player plays everything as progressive. Burn it to a dvd, and the TV shows up the flaws. I would check the field order of good and bad clips to see if this is the case.
Read my blog here.
I have used both tmpgenc and cce to make my final converstion to dvd. Then i use Sony DVD architect to make the menus and burn it onto dvd. Since i encode it as a compatable mpg2 dvd architect doesnt need to reencode it.
guns1inger, thats what i was thinking, that the field orders were different. Is there anyway to fix that after i have encoded it as an avi with vegas? I ask this because i have other videos that do this which i no longer have the clips. I only have the final dvd mpg available.
Thanks for your responses
DVD is jumpy after conversion
By RebelUK in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 29th Jul 2010, 13:04 -
Avi to dvd jumpy..?
By Mozzy31 in forum Authoring (DVD)Replies: 7Last Post: 7th Feb 2010, 04:05 -
Jumpy playback on XP media player
By WBFAir in forum Software PlayingReplies: 7Last Post: 23rd May 2008, 09:26 -
Jumpy playback, dropped frames during capture, CPU pegged to 100%
By tylerz in forum Newbie / General discussionsReplies: 7Last Post: 24th Jul 2007, 17:09 -
Jumpy DVD ?
By Dash1 in forum Newbie / General discussionsReplies: 7Last Post: 2nd Jun 2007, 14:53
