Results 1 to 9 of 9
  1. I just found out that ALL my DVD-R's that I burned with home DVD movies (PRODISC brand, DVD-R5) are not recognized by my home DVD player. They do play nevertheless in my PC.
    As a workaround in order to watch them I transfer them temporarily to a Verbatim DVD+RW5 which is compatible with my home player.
    Can anyone recommend the most versatile and compatible DVD player today in the market?
    Thanks.
  2. I can't remember the last time I heard of an incompatibility problem. Even a new low end model should be sufficient. In the future, test ONE disc on the player and don't wait until your entire catalog is finished. You might want to take one of your discs to a dealer and test before buying. What did you author and burn with?
  3. Originally Posted by alegator
    Thanks.
    Anything new should make you happy.
    If God had intended us not to masturbate he would've made our arms shorter.
    George Carlin
  4. What model of DVD player do you have.
  5. Sony DVP C650D (it's inmy computer details icon).
    I used Nero Burning ROM v6.6, latest version.
  6. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    and dont cross post
  7. I considered another post was necessary as the issue was getting more serious. In this post I was just describing the DVD-R not compatible. The other post you're referring to was generated when I found out that also a DVD+RW was unable to be played.
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Go across to your left and click on DVD Players. Tick off all the features you want in a player in the search area, and see what comes back.
    Read my blog here.
  9. Cool, thanks.
