  1. I used tmpgenc xpress 3.0 to convert my anime file to mpeg, the file had subtitles, and after I used nero to burn it on dvd, the subtitles are way to low on the screen, with only about the top half of the letters being able to be seen. Also, long phrases carry outside of my screen. What can i do to remedy this?
    Thanks!
    Dain
    [img]vba02cbbfe6.gif[/img]
    are the subs permanent encoded in the anime video? then add black borders with tmpgenc xpress under advanced custom size.
  3. Now, I changed the ratio to 1:1 and it fixed the problem of only half the subs being shown, but on long phrases some subs still go too far left and right of the screen, its not THAT bad, but is there a way to fix this using TMPGENC XPRESS 3.0?
