Does anyone know of a audio program that can be used to change between formats different bit rates where you just select one of the codecs on you pc to encode to.
goldwave
vegas
sound forge
wavelab
premiere
protools
well pretty much all of them"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
thanks, also do you know of any audio porgrams that can extract the audio off dvds.
I use DVD Audio Ripper and it couldn't be easier.Originally Posted by Shifty268
Audio Editor - Batch
By BobAchgill in forum AudioReplies: 2Last Post: 3rd Nov 2011, 06:43 -
How do you insert an audio clip between audio clips in AVS Video Editor
By johnharlin in forum EditingReplies: 1Last Post: 19th Apr 2011, 01:17 -
Need free Video editing program that works like regulay 8mm editor
By rwisdom in forum EditingReplies: 0Last Post: 18th Nov 2010, 13:04 -
Audio Editor Freeware?
By Nitro89 in forum AudioReplies: 7Last Post: 14th Oct 2009, 21:38 -
How do I uncensor a censored audio track in an audio editor?
By adidasos in forum AudioReplies: 1Last Post: 19th Jan 2009, 05:40
