I have an NEC3500 and DVD Decrypter only rips @ around 3x. Surely my drive should rip quicker than this?
Cheers, Slave
maybe you have to unlock it by flashing the firmware as they can be limited to this speed by default
http://forum.rpc1.org/dl_firmware.php?category=4&manufactor=23
above is the link where you can find the firmware to unloock your NEC drive so it can rip at a faster speed. -
DVD writers are usually locked to rip at 2x (mainly). the best option is to get a seperate dvd rom drive for the purpose of ripping. this saves wear and tear on your burner and offers faster ripping than anu dvd burners.
Lite On dvd roms have had some good reviews and are known to be the fastest rippers out there. with the prices of dvbd roms being cheap (here in the UK around £15-£20) it well worth getting one. -
Hi MrSlave,
"3x"? That fast...! Count yourself lucky. Check out this thread where I was getting anywhere between 0x and 2x max!!! I got loads of info and advice that may help you.
I've now got a new PC and have the Liteon installed, but have yet to rip so don't know it's speed. I figure it can't be any worse than before!
Hope that helps. Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
With my Lite-On DVD ROM i have attained a 16X max ripping (on a dvd5) and 12X max on a dvd9.
Usually, all dvd5 will rip in under 5 minutes and dvd9 will rip between 10-15 minutes.
Help Ripping DVD by Chapter with DVD Decrypter
By lukebrowning in forum DVD RippingReplies: 3Last Post: 11th Jan 2011, 00:04 -
Trouble ripping The Ugly Truth with DVD Fab HD Decrypter
By heyjjjaded in forum DVD RippingReplies: 1Last Post: 22nd Dec 2009, 14:29 -
Questions About DVDFab HD Decrypter; Ripping MPG
By neumannu47 in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2009, 18:55 -
Any Free Alternative To DVD Decrypter For Ripping To Single VOB?
By DarrellS in forum DVD RippingReplies: 9Last Post: 11th Feb 2009, 00:41 -
DVD Decrypter / DVD Fab - Extremely slow ripping speeds in Vista
By awp in forum DVD RippingReplies: 5Last Post: 19th Dec 2007, 13:11
