Hey i was just wondering where i can download a mpeg 2 codec for virtual dub that lets me convert DV to Mpeg 2
Results 1 to 30 of 60
AFAIK, Virtualdubmod can open MPEG-2, but cannot encode to it. Best way is to frameserve your DV footage into an encoder like CCE or TMPGENC via Virtualdub.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Here's one guide for frameserving from Virtualdub: https://www.videohelp.com/virtualdubframeserve.htm
there is a free MPEG-2 codec available in the tools section under codecs.
You seem to be missing the point though. Virtualdub cannot output to a MPEG file. EOS.
You must frameserve from virtualdub if you wish to output to MPEG.If in doubt, Google it. -
Doesn't the VirtualDub mpeg version not even let you output to mpeg.
I was going to try framserving but i don't even understand what it means! -
No. virtualdub-mpeg2 enables you to open MPEG-2 files. The other variants of virtualdub all enable you to open MPEG-1 files, but none of the can output to MPEG. Got it ?Originally Posted by Shifty268
All frameserving is is a fancy word for opening a file in one program, doing some things to it, and then instead of saving the output back to a file, you "stream" the output directly into anopther program as input. So instead of saving to an AVI, then opening that AVI in TMPGEnc, you cut off the middleman and output directly to MPEG, but by using virtualdub to frameserve to TMPGEnc.Originally Posted by Shifty268If in doubt, Google it. -
You use 'frameserving' to transfer a video file directly from Virtualdub to an encoder. It eliminates the generation of an in-between file and saves time and HD space.
Look here: https://www.videohelp.com/virtualdubframeserve.htm
EDIT: Sorry, jimmalenko
was too fast for me.
And I don't read my own posts.
... apart from the fact that you put this link up first about 48 hours ago thoughOriginally Posted by redwudz
Shifty, despite what I said in the other thread, don't be SORRY to ask any questions, we're all here to help each other.
Yes, virtualdub can open your MPEG file, but I don't know how you'll go adding AC3 audio.
Do you want it as AVI or MPEG in the end ???If in doubt, Google it. -
Don't really mind as long as i can author to dvd in the future. But doesn't and mpeg file have to have mp2 video stream and mp2 audio. Am i right on this one:-
-mv2 file is mpeg video stream
-mpeg file is mv2 video combined with mp2 audio
don't stress about this last quesiton on virtualDub
but can....
You open a mv2 file then add audio to it and save as mpeg as there in know conversion involved.
Im i bit confused about all this shit -
We all were at some point
video stream is a m2v file most likelyOriginally Posted by Shifty268
audio can be ac3, mp2 or wav
No conversion required whatsoever. in combination with your desire to be able to author to DVD at some point, all you need to do is mux (short for multiplex, join in other words) your video and audio together. TMPGEnc can do this for you if you go to file > MPEG Tools, then simple multiplex.Originally Posted by Shifty268
BUT, if you wish to output to DVD, most DVD Authoring packages will accept your M2V and audio file as they are now - separated. So the only reason you would bother multiplexing is if you want to watch it, and not put it to DVD for a while.If in doubt, Google it. -
If i multiplex it will it become a mpeg file ( with mv2 and ac3 audio) or avi ( with mv2 and ac3 audio). so what is the difference between mulitplex and interleave?\
just another thing about virtualdub refering to beofre,nothing to do with above
Say ac3 doesn't work in virtualdub could i still open a mv2 file in virtualdub and add audio to it (wav or something) then save it as a mpeg file as there is no conversion involved.[/u] -
multiplex makes it an MPEG System stream.Originally Posted by Shifty268
If you save to AVI, there is conversion, conversion to whatever codec you choose.Originally Posted by Shifty268
In virtualdub you can open a M2V file and add WAV audio to it if you wish.
Once again (and hopefully for the last time), YOU CANNOT SAVE AS MPEG IN VIRTUALDUB.
I think it's time to stop the questions, and start the doing.
Ask questions when you get stuck.If in doubt, Google it. -
So can you only convert from mpeg to something else
and if you added wav to a mv2 what would the result be -
shifty i'm pretty sure you can use ffdshow to give you a m2v file in vdub. You might be able to do an mpeg but don't think so. you have to save as a dummy .avi and then save as the .m2v file i think but will look again and see.
You can do a similar thing w/YMPEG but it cost money and does not multiplex ither.
Hope this helps
RogThere are many ways to measure success. You just have to find your own yardstick. -
An avi of your choosing.
Do you have a native language other than English in which we could say "VirtualDub does not output mpeg-2" so that you could understand us ?Read my blog here.
You CAN encode mpeg2 from Virtualdub with YMpeg.
Tutorial for encoding mpeg2 from Virtualdub:
http://www.ympeg.com/tutorial.htm -
So is it worth a shit? Have you tried it? What kind of results do you get with it? Sounds interesting.Originally Posted by deckard8"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
Let's just reread something, shall we ?
Originally Posted by jimmalenkoCorrect me when and if I'm wrong, but YOU CANNOT SAVE AS MPEG IN VIRTUALDUB (on its own). You CAN encode mpeg2 fro Virtualdub with YMpeg, or you could save yourself the hassle and just frameserve to your favorite encoder anyway. All YMpeg is is a $25 frameserver (it still requires an MPEG encoder), which Virtualdub gives you anyway for free. So the question is, why would you bother spending the $25 and creating an extra step that is totally unnecessary ?Originally Posted by deckard8
I know where MY $25 is staying ...
Hi Jimmalenko,
YMpeg is an mpeg1/mpeg2 encoder. You're right of course in saying Virtualdub can only output avi, but YMpeg actually bypasses this -
Quote from Tutorial ... "Start compression by clicking 'Save As AVI' from file menu. The filename you enter here will be a dummy file generated by VirtualDub and will not be usable. Actual output file will be the one which you have configured in YMPEG Configuration dialog. -
I haven't tried YMPEG yet beyond simple clip test. I doubt if I'd ever really use it. You see, it DOESN'T do B-Frames, only I- and P-Frames. That makes it pretty worthless for me at this point (and for many of you). Maybe it'll get B-Frames later on...
It is an in-line compression codec, meant to be used as one of many output options for VFW/Directshow apps. It does differ from most codecs in that its final output is an MPEG file, not an AVI file (with or without MPEG compression in it).
Yes, you could use YMPEG as an output option from VDub, but seriously, TMPGEnc or CCE via Frameserving is just about as easy and MUCH more versatile and higher quality, FWIW.
Scott -
mpeg2 is a proprietary codec. IOW, you got to pay to license any encoder you want to use. try looking at www.mainconcept.com for one place to get an mpeg2 encoder
MOBO: ASUS P4P800 Deluxe
CPU: 3 GHz P4
OS: Win 2k SP2
Audio: ECHO Mona
BSCVideo Card: ATi Radeon 9800 Pro
Video Capture: IEEE-1394 DV
HSF: Volcano 5
HDD: WD 1200JB
Video HD: WD1000BB
CD-RW: Sony
DVD-R: Pioneer A03 -
Yes, there really is no Free Lunch with MPEG2...
Might as well pay a decent amount for a very good encoder.
Scott -
So if i used ympeg i could open my mv2 video file into virtualdub then add the ac3 sound and save as avi,, which would save as mpeg through ympeg.
Back to the topic of framserving what is so good about it compared to just saving it to avi?
what is so good about having as mpeg file
just not avi
im just getting more and more confused so ive come to this...
jimmalenko said:
Ok the file is AVi the video formats is DV and the audio PCM the file was captured from a vhs tape through a video camera. I want to make the file smaller beacsue it is 16gb and that a pretty big chunk out of my hdd, i want to make it into a samller file and later be able to author it to dvd, when i purchase a dvd writer.Just tell me what you have available, what you want to end up with, and I'll tell you how to do it wink.gif
virtual dub não abre arquivos cokm codec xvid
By sandroguchilo in forum AudioReplies: 3Last Post: 14th Dec 2010, 16:43 -
ffdshow codec not showing up in Virtual Dub
By uglijimus in forum Video ConversionReplies: 2Last Post: 8th Mar 2010, 15:12 -
virtual dub xvid codec encoding w/o profile
By caner12 in forum EditingReplies: 7Last Post: 5th Jul 2009, 12:08 -
MPEG 2 TS (Transport Stream) in Virtual Dub MOD
By afcoff in forum Video ConversionReplies: 8Last Post: 28th May 2009, 08:58 -
AC3 codec/filter with virtual dub and TMPGEnc
By buzzsaw in forum Newbie / General discussionsReplies: 16Last Post: 24th Apr 2009, 17:47
