Hi, I just burned my first dual layer DVD. I used a Verbatim disc and a Toshiba 2.4X DL burner. Anyway, I authored the dvd with TMPGENC DVD Author (DL Version) and burned with Nero. No problems with the burn (took about 45 minutes...). However, when I play the disc, and I select the track menu, it just stops!
I have the image on my hard drive, and it does go on to the track menu when I select it on my computer. But the new disc does not. Any opionions/suggestions as to what may have happened? I hope I'm making sense...
1) Image works perfectly on my computer.
2) DL DVD stops when I try to access the track menu from the main menu.
Results 1 to 1 of 1
eMARTY69
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 22:52 -
Making a Dual Layer disk with menu
By Regor21 in forum Authoring (DVD)Replies: 7Last Post: 8th Apr 2010, 08:34 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 09:00 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 13:39
