I'm in this for the challenge now.
I demux out the sound using DVD2AVI. If its WAV, its cool. If it's AC3, I think there's a little more work. I'm unsure of how to handle an AC3 track.
Using Tmpeg2.5, I can convert the video portion to NTSC MPG2. I'm guessing I have to use BeSweet to convert PAL AC3 to NTSC AC3. I'm not sure of how to correct the offset (-404ms, etc). Will BeSweet maintain the skew in the NTSC conversion or output with a new time offset?
I was thinking of then MUX'ing the video and audio together, and re-author; or use something like DVDLab to author and give it the sound and video separate.
Anyone have thoughts on the sound part?
O.
Originally Posted by orion940
As for the audio ... it depends. If you use the frame rate slow down method (which works with a progressive source) then you need to slow the audio down.
Best way is to do that with BeSweet. It will account for the delay. It is best to convert the AC-3 to a PCM WAV file ... you can account for the delay here but don't do the PAL to NTSC option. After you get the PCM WAV file you can create a new PCM WAV using the PAL to NTSC option. Then you can use that PCM WAV as is or convert it to MP2 or AC-3. I've found it is best to conver the PAL AC-3 to a PCM WAV file first doing no "fixing" other than the delay THEN you can fool around with it to your heart's content. In other words don't try to go straight from AC-3 to AC-3 with the PAL to NTSC option otherwise you very well might end up with slightly out-of-sync A/V.
If you use the AviSynth method then the audio as is will be fine though you probably should accont for the delay. That can be done with AC3 Delay Corrector.
- John "FulciLives" Coleman
P.S.
See this here thread:
https://www.videohelp.com/forum/viewtopic.php?t=219852"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
I missed that other thread completely. I never searched in that thread, as it didn't seem like the thing to do at the time
Thanks for the help.
O.
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 15:17 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
PAL .VOB to NTSC .VOB Sound out of Sync
By zaque2004 in forum ffmpegX general discussionReplies: 4Last Post: 15th May 2009, 08:59 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
Convert NTSC VOB --> PAL VOB
By djdust in forum Newbie / General discussionsReplies: 2Last Post: 5th Dec 2007, 11:29
