What's the resolution for widescreen dvds? When I encode a 720x480 video for dvd, I get black bars on the side. Using TMPGEnc 3.0 XPress. Thanks
I figured it out, had to switch from full screen to center under the edit options.
I think TMPGEnc Plus (don't know about the new one) tended to size things to a width of 704 with 8 black pixels on either side.
Depending on the source this is sometimes correct ... somtimes not.
Many commercially made DVD discs have a bit of black on either side.
You never see it on a TV because of TV OVERSCAN.
which resolution for 32" widescreen?
By iancur in forum Video ConversionReplies: 1Last Post: 2nd Feb 2011, 14:48 -
42 inch plasma widescreen (16x9 hdtv has native resolution 1024 x 768 (4x3)
By sbt5 in forum DVB / IPTVReplies: 15Last Post: 4th Aug 2009, 22:59 -
vertical resolution of anamorphic widescreen?
By Sean_ve99 in forum Video ConversionReplies: 12Last Post: 7th Jan 2009, 12:41 -
PLASMA resolution..1024x1080 (or 1024x768) ..surely isnt widescreen?
By snadge in forum DVB / IPTVReplies: 6Last Post: 2nd Sep 2007, 12:24 -
My widescreen slashes resolution
By seragx99 in forum Video ConversionReplies: 1Last Post: 5th Jul 2007, 03:38
