I just purchased a toshiba rd-xs32 and I would like to know if anyone has experience with this recorder. My daughter is moving and I want to purchase a dvd player, can anyone recommend a cheap one that works well with the xs32.![]()
WHEN THE GOING GETS TOUGH, THE TOUGH GET GOING!
I don't understand what you mean by "works well with the xs32." You want your daughter to have a DVD player that will play DVDs recorded on the Toshiba, right? Just record in video mode and finalize your discs. They should play in probably any currently made DVD player.
I keep reading about this black level issue, I was hoping that there is a player that doesn't have this black level problem when playing back dvd's made from the xs32
WHEN THE GOING GETS TOUGH, THE TOUGH GET GOING! -
I have one and no problems.. admitedly in the uk.
Just make sure any machine you get for your daughter likes DVD-R's and DVD-RW's then you should be ok... and if its also DVD-RAM compatable all the better.. -
I just purchased the next level up RD-XS52 (160G HDD) aabd it does NOT make DVD's that will play in just about every recorder. I thought that I may not be setting something up correctly so I called the Toshiba customer service hot line for help. I explained that so far, I was able to find only 1 DVD player (a Sony) that would play my DVD recorded from the Toshiba unit. I've tried playing them in a Panasonic, JVC, GoVideo, and my combination TV - no luck.
Customer Service said that it was a compatablility problem. I just can't believe that this unit would not be compatable with the maority of DVD players. But that appears to be the case. I'm very disappointed. -
Originally Posted by cr8zycat
It's a matter of finding a DVD player that supports DVD+-R/RW formats. Anything older than 2 years probably doesn't.
toshiba sdp95swb
By paul72 in forum Newbie / General discussionsReplies: 1Last Post: 27th Dec 2011, 04:51 -
Toshiba dkvr60ku
By bukijami in forum DVD & Blu-ray RecordersReplies: 1Last Post: 10th Nov 2010, 16:28 -
Toshiba RD-XV48DTKB
By maggiechow in forum DVD & Blu-ray RecordersReplies: 6Last Post: 24th Oct 2010, 12:29 -
Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
By renavspainatal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Nov 2009, 08:59 -
Why is the Toshiba HD-A2 Better Than the HD-A3 ?
By ofield1 in forum Newbie / General discussionsReplies: 5Last Post: 4th Mar 2008, 15:57
