Hey all. Ok, I have two AVI's that have a framrate of 14fps. It also has an audio of MPEG Layer 3 and video compression of MPEG4 V3. What do I need to convert this over to burn it to a DVD? I tried TMPENG and it converted it but the audio did not match up with the video. I'm lost now. Never came across this before.
Thanks a million
Jen
if you had procoder express or pro ... you could do the video conversion to 23.976 ok ... but i know for a fact that the audio will be out of sync still ..
i would use vegas to re-sync it up to the new video"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
So should I convert it to the new rate and then use the vegas to resync it? Never used that before, is it hard?
not hard --
but not that cheap either -- 30 day trial though"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Weird problem converting VHS tapes
By bessiecat in forum Capturing and VCRReplies: 9Last Post: 3rd Mar 2012, 01:10 -
Something weird is happening here...
By montreal in forum ComputerReplies: 4Last Post: 21st Dec 2011, 15:23 -
Weird Effect help?
By MurbeckJackson in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 30th Jan 2011, 06:22 -
Weird, very weird thing demuxing a DVD
By jairovital in forum EditingReplies: 17Last Post: 22nd Oct 2010, 18:31 -
Weird problem converting AVI to H.264
By lequis in forum Video ConversionReplies: 1Last Post: 20th Dec 2007, 08:19
