I was looking to buy a external capture device and was wondering if the video card had anything to do with the capability of capturing.
Thanks for the help
"Do or Do not, there is no try"- Yoda
If it is a standard video card, with no video-in capabilities, then it will have very little impact (a very old card might slow a system down, but it would have to be very old). The major things that impact capturing adversly are
1. Not enough memory (512mb should be considered the minimum)
2. Slow hard drives - at least 7200 rpm. Your capture drive should also be defragged before capturing, and should not be your system drive.
3. Too many other things running. If possible, take you PC off the net when capturing, and shutdown anything running in the system trayRead my blog here.
Disable the preview if your system isn't very fast.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
And turn off the screensaver if it's on
Virus scanning software can also slow things down and lead to dropped frames. Turn off any Auto-protect virus scanners before capturing.
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope"
Newbie question - capturing and converting from DV
By zaspa in forum Newbie / General discussionsReplies: 8Last Post: 31st Aug 2011, 16:56 -
Which video editor for this effect? (a noob question)
By thea in forum EditingReplies: 5Last Post: 26th Apr 2010, 08:51 -
Capturing HD Video -- (NEWBIE)
By PixelBucks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 24th Jun 2009, 12:31 -
Help for newbie I need to add a Tsunami effect to a video
By coalfire in forum Newbie / General discussionsReplies: 1Last Post: 28th Nov 2007, 16:27 -
Newbie question on Capturing to Encoding
By Lucky19th in forum Newbie / General discussionsReplies: 10Last Post: 16th Jul 2007, 14:09
