Some of the files I open with TMPGEnc say "File: "the file name.avi" can not open, or unsupported."
I can't figure out why some of my files will open and some won't. I tried converting them with EO Video with no success. Does anyone know what the problem is? I'm trying to convert them to VCD so I can put them onto a DVD.
Every woman is a black woman.
oops sorry. I'll post this under the conversion forum. My mistake =)
Every woman is a black woman. -
Providing there is nothing wrong with the AVI file, the usual cause of problems opening an AVI in TMPGenc is the VFAPI plugin needed to decode the video is either missing or is being intercepted by another plugin.
Under 'Option' -> 'Environmental Setting' - 'VFAPI plug-in' you will see a list of Readers and decoders. Try giving the 'AVI' ones a higher priority (right click and select higher priority, or right-click the others and give them a lower priority), you want the AVI ones to appear at the top of the list. If you have a 'DirectShow' plugin, move this one towards the top aswell.
If you still have trouble, try turning all the plugins off and then turn each one on seperately (leaving all others off) and try opening the AVI, once you have found the right one, move it to the top and then turn all the others back on.
Can not open any file in TMPGEnc 4
By Soixante in forum Video ConversionReplies: 4Last Post: 8th Sep 2010, 08:56 -
can't open file in TMPGEnc
By windranger in forum Newbie / General discussionsReplies: 12Last Post: 18th Feb 2009, 09:25 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
TMPGEnc Plus 2.5 saying unsupported??
By Suprman37 in forum Video ConversionReplies: 10Last Post: 12th Oct 2007, 17:51 -
cannot open or unsupported file on tmpgenc
By Donna Stefani in forum Video ConversionReplies: 6Last Post: 15th Aug 2007, 20:31
