Hi,
I've burnt a couple dozen discs with no problem. Now suddenly when I put in a blank disc the drive it does not read it and tells me the drive is empty and to put a disc in the drive. I also notice that when the drive is empty, windows explorer will describe the drive as a DVD-RW drive, but once I put a disc in it switchs to a CD drive. It will still read burnt dvds even after this description, but blank ones are not recofnized.
I have not changed my hard ware or software since this happened.
Any help will be greatly appreciated.
Results 1 to 13 of 13
Go to windows device manager and remove the device then re-boot the computer. This will force windows to re-install the device. Be sure to go back and look in device manager to confirm the drive is in DMA mode.
Sorry, but that did not work. It still won't read blanks. Any other suggestions?
When I go into the device manager, the drive is identified correctly but it is listed as a DVD-CD-Rom drive. Shouldn't it be listed as a DVD-RW drive?
my dvd player has the same problem currently!
except i cant recognize any dvds.....movies or blanks.
help! -
OK, Things are getting stranger. I flashed the firmware to 2.18 and it didn't solve the problem. No surprise there since the nec 2.18 is a minor upgrade.
If I start nero and try to burn to the DVD-RW drive, nero refuses because there is no disc. If I load a blank CD in my second lite-on combo drive, windows pops up its screen asking me what I want to do. I tell it to burn in nero and then nero will allow me to burn the dvd that we "not there" before and they burn properly and at the same speed.
I can live with this, but it would be better to fix it. Any suggestions. -
It appears to be the new DVD recorder sickness!
Got myself a new Samsung TS-H552. Recorded succesfully a couple dozen DVDs and CDs. Then, all of a sudden, it didn't recognise CDRs at all. Could read CDs though and DVD reading and recording was not affected.
Took it back to the store, explained, and they replaced it on the spot. They stated that 1/3rd of DVDRWs (all makes!!) are returned for the same reason. (!!??).
My suggestion: Take it/ Send it back now that it's new and get a replacement. Thank yourself it failed sooner than later...The more I learn, the more I come to realize how little it is I know. -
ive had this happen to a few burners, both old and new. its pretty gay, b/c it doesnt look like there is a way around it or to prevent it.
ok. post back if u read this cos its not very cool people taking back working dvd writers when the problems with ur OS. type autofix.exe on google and then find the microsoft website and download autofix.exe and run it on whichever drive isnt working and itll fix it. happy? :0 dont take ur dvd drive back like guy. its just ignorance
tic
Does anyone having this problem have Roxio burning software installed (EZ CD Creator 5, 6, EZ Media Creator 7)? I was having a similar problem when I loaded a blank DVD disc in my NEC 3500 or LG GSA-4120B. The computer refused to acknowledge there was any blank media or any media at all in any of my drives. Usually a blank window pops up telling me that a piece of blank media that I inserted was recognized, but when my system refused to recognize any blank media the window never appeared. How I soved this problem was to uninstall Roxio EZ Media Creator 7. I then rebooted the system and after reboot reinstalled EZ Media Creator 7. After install I then rebooted the system again and now blank media is recognized again. I can't guarantee that this will work for you, but it worked fine for me. Good Luck!!!
I just got the NEC 3500 the other day bundled with Roxio software. From past experience, I never install bundled software because 9 times out of 10 it's usually crap. That's one of the reasons that it's free.
I am Jack's medulla oblongata
Blank Blu Ray Discs
By anthonyfellows in forum ComputerReplies: 1Last Post: 10th Dec 2010, 18:46 -
OPPO DV-981HD No Longer Plays PAL Discs
By elling in forum DVD & Blu-ray PlayersReplies: 10Last Post: 3rd Sep 2010, 18:38 -
3D DVD Blank Discs
By tealmarlin in forum MediaReplies: 7Last Post: 24th Aug 2009, 18:03 -
Do 20GB Blank Discs Exists?
By PHNeedsHelp in forum Authoring (DVD)Replies: 1Last Post: 23rd Apr 2008, 18:51 -
which blank discs to use for recording
By Lea Ann in forum Authoring (DVD)Replies: 12Last Post: 2nd Feb 2008, 23:46
