I purchased a Pioneer A08 DVD burner in an enclosed firewire/USB 2.0 case. It will not burn when connected to my XP Professional system where I do all my capturing, editing, and authoring. Every burn program I try (RecordNow, NTI...) will not work. My internal A05 works great (at 2X). I then take it and hook the external A08 up to my old Compaq Presario 1700 running ME via firewire and it will burn with no problems. What kind of setting am I missing on my XP machine that would cause this? I just keep getting an error saying it cannot burn (after making a coaster of the DVD-R).
Thanks in advance
Is your burning app seeing the writer? Check all the menu items to see if there's a screen to select the device.
If it isn't, then maybe your PC isn't seeing it. Go into device manager and check the CD drives listed. If it isn't there, there may be something wrong with your USB connection. Also try another USB port
If your PC sees the drive, but the burning app still doesn't, try Nero. It has a screen where you can manually select which burner you wanttu use, and you can see right away if it's even recognized by the app. If it is, select it and it should work then. -
Could be a bad Firewire port on the PC. Might need to replace it if possible.
PC sees the drive as does the software. This happens whether connected via firewire or USB 2.0. It will burn for about 1 minute and then stop. I will have to get the exact error message.
Thanks for the replies.... -
Are the firewire and USB 2 ports PCI cards? I have the exact same problem with my new USB 2 A08 yet it works fine with a newer PC that came with USB 2 ports. With the PC that I added a USB 2 PCI card, the A08 will burn for 1 minute than fail. The problem is my older PC is the one I do all of my video editing on and I need to burn DVD's on it so it looks like we're in the same boat.
seandvd -
The firewire is PCI but the USB is a front loader. We are just the opposite. The burner will not work on my new Gateway running XP Professional but will work on my old Compaq laptop running ME. Go figure...
Thanks for the reply!!!! -
Ok when I try to burn a disc, I get the following error after less than a minute:
"There was a problem writing to the disc. You can try again by clicking the Retry button. You will need another blank disc ready."
When I click on the Advanced button, I get this:
Sense: 00 ASC: 00 ASCQ: 00 (Command 2A)
Px.dll: 1.7.46.500
pxdrv.dll: 1.0.61.2
PxMas.dll: 1.7.46.500
PxWave.dll: 1.7.46.500
PXWMA.dll: 1.0.0.3
I then connect it to my Compaq Presario 1700 laptop via firewire and it works fine.
Any help would be greatly appreciated... -
I'd suggest you post your problem at the Pioneer Forum at cdfreaks.com. They have people there that can help you out.
Pioneer DV-3022KV
By azfarhus in forum DVD & Blu-ray PlayersReplies: 11Last Post: 24th Mar 2012, 03:37 -
Pioneer DVR
By vcd4me in forum DVD & Blu-ray RecordersReplies: 20Last Post: 25th May 2011, 00:33 -
Pioneer DV-F727
By captainneek in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Jan 2010, 13:59 -
Pioneer 531H
By cscasto in forum DVD & Blu-ray RecordersReplies: 4Last Post: 6th Nov 2008, 20:19 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 06:02
