Hello, peeps!
I've connected my VCR to my TV-card (which is Pinnacle PCTV Pro) through the composite "hole". The program I'm using to capture video is PCTV Vision, which I got with the card. Anyway, I'm trying to record a trailer off the Face/Off VHS (PAL), but when I hit the record button the video goes all crazy and "mixes" with different scenes. Here's a video to illustrate just what I mean by that.
http://www.jbfans.com/temp/trailerVCD.mpg (8 megabytes, VCD)
After about 20 seconds the video goes back to normal (as you can see in the example I've provided), but it doesn't always do that. I've noticed differences when I record to DVD format and VCD/SVCD format. This is recorded in DVD (I just converted it to VCD so the file wouldn't be too big and you guys could watch it), but when I record to VCD/SVCD the video doesn't flicker like that at all, instead the video speeds up, like someone hit the fast-forward button.
These are the settings I have in the PCTV Vision program:
The system I am using is:
Windows XP Home Edition
AMD Athlon XP 2400+ (1.99 GHZ)
1024 MB in memory
GeForce FX 5200 128 MB
75,5 GB harddrive
Pinnacle PCTV Pro card
So, can anyone tell me what the hell I am doing wrong here?
UPDATE!
I've also noticed that the video flickers sometimes even when I'm just playing the video.
Results 1 to 1 of 1
It's All Good.
pinnacle pctv 310i
By marc21782000 in forum Capturing and VCRReplies: 10Last Post: 4th Jan 2010, 02:30 -
Pinnacle PCTV HD Pro Stick, my experience
By vhelp in forum DVB / IPTVReplies: 46Last Post: 14th Oct 2009, 19:36 -
What software for Pinnacle PCTV HD?
By tomreedtoon in forum Capturing and VCRReplies: 10Last Post: 9th May 2009, 06:14 -
Audio problems with Pinnacle PCTV HD Pro Stick.
By cactusjack310 in forum AudioReplies: 0Last Post: 21st Jan 2008, 17:16 -
Which is best, Pinnacle 110i or PCTV Pro PCI
By brvignesh in forum Capturing and VCRReplies: 23Last Post: 28th Nov 2007, 22:40
