  1. Hi
    After i have specified the audio and video files, set my source range, and when i press START to encode i get the following Error
    "Index of scan line is out of range(272)"
  2. Member daamon's Avatar
    Melbourne, Oz
    Hi notbothered,
    If it's the same file that you were using here then it's probably because it's a defective source file.
    Re-rip it from the DVD again, convert to Xvid again and then see if that's OK....
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. Hello notbothered,
    Try scanning for bad frames. There is a guide at https://www.videohelp.com/forum/userguides/153907.php. See if that helps.
    It doesn't matter who you vote for. The government always gets in.
