Greetings,
I have a generic DVD-ROM drive and a DVD+-RW drive. I burned a backup copy of a movie onto a DVD+R disc. The disc plays fine on my home DVD player and on the DVD+-RW drive. But when I insert the disc into the DVD-ROM drive, my computer says that there is no disc in the drive.
Is there a firmware update for a generic DVD-ROM drive that can fix this?
Thank you for any help.
It might be the media. I had something similar happen to me when I was using cheap media. Have you tried other DVD+R media?
If that's not the case ... How old is your DVD-ROM drive? Some older drives might have problems with DVD+Rs. If that's your problem then ...
You might check to see if there's a firmware update for your DVD-ROM drive. You could go the drive manufacture's website to check or do a google search.
DVD-ROM doesn´t read DVD
By jsilv in forum DVD RippingReplies: 11Last Post: 7th Mar 2010, 07:43 -
Hybrid disc with both DVD-Video & DVD-ROM - is it possible to burn?
By rjamesd05 in forum Authoring (DVD)Replies: 5Last Post: 18th Sep 2009, 14:07 -
Cannot burn to a DVD disc and DVD RW-drive changed to CD-drive after copy
By coody in forum DVD & Blu-ray WritersReplies: 0Last Post: 13th Sep 2009, 05:18 -
Replace dvd drive with dvd-rom drive.
By jtrapat1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Dec 2008, 11:33 -
hd-dvd rom drive
By computerchuck in forum Software PlayingReplies: 6Last Post: 8th May 2007, 08:55
