i searched the convert section in the left menu, but i couldnt find a guide that could help...what i want to do is convert a PAL dvd to NTSC and be able to keep the dvd menus it has, how would i do that?
Results 1 to 12 of 12
No guide because it is way too much work, convert all video, audio, extra material, menus, menu background audio and still pictures. And no all-in-tool can do it either( yet). Get a cheap dvd player that can convert PAL to NTSC.
i have a sony TV dvd player, it works fine in my xbox, since i modded it, but im tryin to get it to wokr in my sony TV dvd player its a new player...i got it like 3 months ago...
this dvd player wasnt cheap...$100 for this sony...there were dvdplayers that were $30 that i could have played pal on, but i dindt realize and i thought sony was a better brand :/
You need a "code-free/region-free" dvd player that plays both Pal and NTSC and sends the signal to your NTSC TV so it displays the picture correctly.
Do a web search for it. Saves the hassle of having to convert. -
Do a search for the model # you have to see if there is a remote hack to make it able to play PAL DVD's.
Here is a starting point. Mods if needed please remove the link.
http://www.regionfreedvd.net/player/sony.html -
nice site, but, i don thave a PDA or laptop
, that is what is needed for my dvd player
You might try THIS GUIDE but you're better off buying a multi-system DVD player with a built-in converter.
thanks, i tried that guide but it didtn work, my dvd player would say it cannot play that dvd.
The major problem with the "get a different DVD player" recommendation is that it doesn't cover all of the bases. Yes, it's great for my personal collection-- but what about when I take that same movie to a friend's house or if said friend borrows it independently?
On another note, what about movies that are only relased in Europe, but I want to buy and convert so I can give them as gifts? (This is my current situation.)[i.am.quiller]
simplicity rules
DVD PAL to NTSC or NTSC to PAL DVD Conversion
By Baldrick in forum DVD RippingReplies: 21Last Post: 12th Apr 2016, 18:30 -
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 12:30
