I have downloaded a movie in bin file format and successfully changed it to mpeg. when i change from mpeg to dvd and burn it there is a thick green line down the bottom of the screen is there any way to crop this or what is the cause of it and can i stop it happening.many fanx![]()
Hello,
You can load the mpeg into tmpgenc and choose the clip option (can't remember where it is..). Then you can crop a fresh crisp black bar over the green line....
Kevin
--though of course you'll have to reencode the whole movie, don't know how to prevent it from happening, maybe get a cleaner version somewher???---Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
If your only going to view it on a TV ignore it. It won't be visible on the TV, it's just in the overscan area.
I need help with cropping!
By UnD3R0aTh in forum DVD RippingReplies: 23Last Post: 23rd Mar 2010, 02:33 -
Cropping...
By bsuska in forum Video ConversionReplies: 40Last Post: 15th Jul 2009, 16:27 -
cropping
By mwh99 in forum EditingReplies: 2Last Post: 7th Nov 2008, 13:25 -
Cropping DV
By bsuska in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2008, 11:31 -
cropping
By exekutive in forum ffmpegX general discussionReplies: 5Last Post: 25th Aug 2007, 01:02
