  1. I need some help in my neverending quest in converting streamed VOBs to DVD –*this is working sometimes but more often not ...
    I am streaming movies from a pay per view box (dbox II) running an open-source Linux software to the Mac. Playing them under VLC is no problem, usually all audio streams are shown as well (it´s usually either two MP2 streams – german and english – or those two and a third one (AAC)).
    I can demux them using bbdemux, although the second mp2 stream comes without file extension. Trying to demux them with ffmpegX results in less or no audio files.
    I cannot author them in the tool´s section of ffmpegX. I got a "unkwon file format" error for either stream (yes, Quicktime shows/plays them)
    Sometimes I can author them via Sizzle, but often it rejects the audio streams or, when succeeding, the audio runs unsynchronized when previewing via DVD player.
    I guess there´s something with the VOBs that does not go with what the applications expect. But seeing windows applications routinely working with theses files I surely hope Mac programs can learn as well. I also noticed that ffmpegX often gives a different ratio than quicktime.
    I´d like to upload little snippets somewhere so that maybe one of you can give me a hint. And yes – I´d like to author them into DVD format –*less conversion time and I want to preserve all available audio formats.
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Trust ffmpegX over QuickTime when it comes to resolutions.
    Jan 2003
    Florida
    Have you tried using MPEG Streamclip to demux the streams? I think Streamclip was made for the type of streams you describe.
  4. Woooooow !!!
    Thanks a lot! I did not hear of this one before. Yes, it´s working fine. You just helped me a loooong way further.
    Thanks!
    Uli
