Hi Everyone!
I'm new to dealing with SVCD. I bought a DVC II and made a few great quality vcds. However, it didn't satisfy me because I'm looking for something similar to DVD grade but with much lesser cost and seems to me SVCD is what I'm looking for.
Anyway, I tried capture the movie with the highest quality format possible (DVD-mpeg2) and then use TMPGEnc. to encode it into SVCD. I followed the instructions listed under the "How To" and got an excellent quality of the movie and then burn it onto the CD-RW for testing.
It was fine when I play the disc on my PC but the movie was jerky when I played it on my Pioneer DV-434. I check and my player supports SVCD. I try using different bitrate and ways to encode the movie but the result was the same. Can anyone give me a help?
Results 1 to 1 of 1
not having any luck creating my tutorials
By Dire in forum Newbie / General discussionsReplies: 3Last Post: 3rd Apr 2012, 22:12 -
Anybody have any luck hacking TV/DVD combos?
By Martineaux in forum DVD & Blu-ray PlayersReplies: 2Last Post: 13th Mar 2012, 11:54 -
anybody had any luck with playing divx softsubs in Wmp 11 ?
By davexnet in forum Software PlayingReplies: 1Last Post: 12th May 2011, 01:02 -
System Running Slow when running dvdshrink
By mn072065 in forum ComputerReplies: 7Last Post: 24th Mar 2009, 19:59 -
No luck with ffmpegX - mencoder segmentation fault.
By jonnymorris in forum MacReplies: 4Last Post: 2nd Mar 2008, 13:07
