I know a lot of you who saw this DVD Recorder at Sams Club for $139 didn't care for the picture from the tuner, well if you change your coax cable and use the new R6 Quad found at some Wal-Mart and CCity Stores under different labels but they are the extra same cables just cost more or less.
Get rid of those poor spiltters and buy yourself some AR 2050 MHz (2.4GHz) digital splitters or Monster versions. Start from the source and once you do the tuner in the Liteon 5101 will produce better pictures with less noise. Direct connect though the Standard Video with gold EFMI cables will produce better pictures.
