I just picked up a NEC ND3500A. ANd for some reason Nero Burning Rom doesn't see it. I'm using firmware 2.18. I also using Nero 5.5.10. I read a few people here using Nero to burn with this drive, I was hoping some of you could help me out.
I was able to burn with Roxio. So I know it's working, but I'd rather use Nero to burn. Any ideas?
Thanks,
Eric
update Nero then delete and re-install your drive from device mgr
only_emo_kidGuest
/\ I wasn't being a jerk saying it worked fine for me or anything, i'm just saying.. I didn't have any problems once I put the drive in and set the jumpers.. i love it!!!!!
What RabidDog said.
And if you are using the last version of the 5X series of Nero (551056) and it doesn't recognize your burner, you would probably have go to the 6X series. There are also free burners in the 'Tools' section <<< if you don't need all the Nero extras.
NEC NDH80 Gone B&W
By bawpcwpn in forum DVB / IPTVReplies: 1Last Post: 11th Jun 2008, 15:23 -
NEC AD-5170A Questions
By urb1972 in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Nov 2007, 21:39 -
NEC DVD burners
By RapidRio in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jul 2007, 22:07 -
NEC DVD Drives
By RapidRio in forum Newbie / General discussionsReplies: 1Last Post: 5th Jul 2007, 14:13 -
NEC NDH81
By babagoi in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 20:05
