I have a 2001 Gateway desktop computer with two 1.1 usb ports in the front and two in the back. What is a cheap solution to getting a 2.0 installed? I recently bought a ATI USB 2.0 Tuner for my laptop, but installing it on the laptop didn't go so well. Know anyplace online I can order from?
All you need is a usb2.0 card that will work fine, are you in the UK or US.
Fleabay would probably be a cheap place for a card or newegg in the States (everyone here seems to rave about it) or in the UK I use a company called overclockers.
AverTV USB HD DVR or Hauppauge USB HD PVR
By gll99 in forum Capturing and VCRReplies: 34Last Post: 8th Jun 2015, 10:56 -
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / IPTVReplies: 8Last Post: 30th Nov 2010, 17:03 -
Question about deleting USB drivers to fix lack of USB notification
By jimdagys in forum ComputerReplies: 13Last Post: 15th May 2010, 11:24 -
Cinergy 400 USB & pcmcia»USB 2.0 difficulties
By AEN007 in forum Capturing and VCRReplies: 0Last Post: 4th Mar 2009, 02:21 -
Can a usb mass storage mp3 player and usb harddrive coexist in vista?
By yoda313 in forum Off topicReplies: 3Last Post: 5th Aug 2007, 19:23
