I've been crusing at 512mb or ddr ram since one of my other sticks died some time back...just popped in its replacement![]()
Is there a huge difference between 1gb and 1.5gb of ram too?
more is betta like chedda...of course that damned third tag along doesnt have dual channel......
I used to have 1gb on my PIII 1ghz and personally didn't notcie a huge difference. sure it was faster but it really wasn't anything to write home about. Maybe it works better on a bus faster then 133mhz.
Guess it would depend upon the circumstances, you see a big difference between 512 and 1024 because XP sucks up about 220 - 250, anti virus, firewall, whatever else you have running..... Not much left after all that if you have 512.Originally Posted by Red96TA
If you were working on say multiple large images at once, yes you would see the difference. Under normal circumstances probably nothing noticeable. -
More isn't always better. Unless your system is utilizing at least half of it at least half the time then you're probably getting worse performance. Likely it would only be helpful if you're running a lot of DCC/CAD/multimedia applications open all at once and going between them. Otherwise you'll probably not use more than 1GB. The problem lies in addressing all that memory for use with your system. Unless you're using registered chips than you probably won't have any issues, but usually only server boards accept registered memory.
FB-DIMM are the real cause of global warming
OMG I made a stupid mistake with formatting an icam.........HELP!!!!!!!
By oops in forum Newbie / General discussionsReplies: 6Last Post: 24th Sep 2011, 19:07 -
NERO 9: OMG what a monster!
By jsmithepa in forum ComputerReplies: 16Last Post: 21st Apr 2009, 21:09 -
What's the difference between these two products?
By Waterkips in forum Capturing and VCRReplies: 1Last Post: 21st Apr 2008, 01:40 -
iTunes on 512mb?
By kbRenePerez in forum Newbie / General discussionsReplies: 3Last Post: 21st Dec 2007, 22:07 -
Can YOU Tell the Difference ?
By Seeker47 in forum DVB / IPTVReplies: 14Last Post: 19th Nov 2007, 13:59
