Hi, i got some DVD video from my friend..However, I would like to redece the bitwave as well as the dimension of the video (from 720x480 down to 352x240) so I can consolidate couple discs into one.
just wondering what software I can use. I tried with TMPEGENC, however, it only works on the first chapter of each disk but not others (don't know why, can read others). What software can help me to reduce bitwave on a VOB file?
thanks
Altering the dimensions doesn't affect video size - only bitrate and length (in time) do. Making the dimensions smaller however allows you to use a lower bitrate without adverse side effects.
Rip the DVD.
Extract the m2v from the VOB set, reencode with TMPGEnc (or other encoder) at lower bitrate/resolution.
Extract audio from VOB set.
Author as DVD with new m2v and extracted audio
/Mats -
thanks
but what software to extract the m2v and audio from the VOB set?
btw, I think I didn't mentioned it clearly in my original post, I don't know if that would make a difference.
the DVD video I got from my friends are not commerical DVD, they are DVD-r that my friends made originally from some Real Video files. So, since they are DVDR video, do I still have to extract audio/video seperately?
thanks
Originally Posted by mats.hogberg -
Originally Posted by softech
/Mats
Reduce file size .
By pensioner in forum Newbie / General discussionsReplies: 4Last Post: 10th Dec 2010, 14:08 -
Reduce file size
By windranger in forum Newbie / General discussionsReplies: 1Last Post: 13th Aug 2010, 09:18 -
How to reduce the size of an MP3 file ?
By SingSing in forum AudioReplies: 18Last Post: 28th Dec 2009, 05:40 -
Need to reduce video size to less than 195MB
By EMK5810 in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2009, 01:22 -
Reduce size of video
By von_25 in forum Newbie / General discussionsReplies: 2Last Post: 27th Sep 2008, 07:25
