Is there any writer out there that can do rewritable DVD9? So I guess it'd be called dvd9-rw.
Thanks,
Lucas
Results 1 to 9 of 9
No, there is no such animal yet nor the media to support it.
Tom -
Originally Posted by cubOriginally Posted by jtommyj
I have a habbit of writing my production to a "RW" media before burning to a permanent media. This is not good then
Originally Posted by ckwok1
Reflection of laser light off the metal/dye.Want my help? Ask here! (not via PM!)
That's always wise to try it out first on RW before committing it to R. Most of us don't do that because of the added time ...and the extremely low cost of R media lately.
It's specially smart with the cost of DL being as high as it is. Too bad there isn't DL RW yet. But, like everything else in the past, you usually see them show up eventually. -
"you usually see them show up eventually" No, lightscribe hasnt appeared yet .. I somehow doubt if dvd-rw9 will appear.
shoot the damn wabbit!Corned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
How to copy DVD9 with subtitle & Burn it in DVD-/+R or DVD9
By prithvi in forum Newbie / General discussionsReplies: 15Last Post: 19th May 2010, 11:37 -
DVD9 to DVD9 2 angles layer break problem
By JoeBolden in forum DVD RippingReplies: 4Last Post: 14th Jul 2009, 19:17 -
having trouble backing up dvd9 to dvd9
By Chunking in forum DVD RippingReplies: 9Last Post: 13th Oct 2007, 20:34 -
DV+Rewritable
By knowmyname_20 in forum Newbie / General discussionsReplies: 1Last Post: 25th Sep 2007, 09:58 -
Rewritable DL ???
By fredfillis in forum MediaReplies: 13Last Post: 30th May 2007, 19:49
