Hello,
I would like to know which authoring software has scene detect function during capturing or when importing an existing avi file or for both ? Thanks.
Originally Posted by BJ_M
maybe it could not detect a scene change because the scene change was to subtle ..
btw -- you have to tell it to do it ... it just doesnt do it on its own ..
takes a bit of time also .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
well that is not authoring by a long shot
Detect Scene Change in x264
By Anakin in forum Newbie / General discussionsReplies: 3Last Post: 9th Feb 2012, 19:31 -
Simple DVD editing and encoding software? (Scene release)
By djkilla in forum Authoring (DVD)Replies: 4Last Post: 18th Nov 2011, 08:48 -
Recommended dvd authoring software with manually chapter function...
By Conrad007 in forum Authoring (DVD)Replies: 14Last Post: 27th Feb 2011, 12:54 -
Freeware CD burning software with normalizing function req
By boing in forum AudioReplies: 2Last Post: 15th Sep 2007, 12:03 -
Detect scene changes in Avisynth?
By AlanHK in forum EditingReplies: 0Last Post: 12th Aug 2007, 06:12
